Need help with TWIDO!!!!
karlag
Mar 2006
Canada
81
Hi evrebody! I am new here and in PLC programming.
Need help with PLC TWIDO. How should looks ladder in order to do next: 1.In the end of program buzzer is ON
2. power off(main switch off and PLC power is off)- E-stop
3.and after PLC power back up buzzer should be still ON
Thank you!
One method would be to write the value 1 into a holding register like %MW0 when the buzzer should be on and a value 0 when it should be off. Then use the first bit of the register %MW0:X0 as the contact that controls the buzzer.
A second, and maybe more common, method would be to use SET and RESET coils.
hi every one how are you . i have this question maybe it is silly but i have no one to help me. i have twido plc and i need to send and recieve...
1,753
hello friends this is the first time to start program with twido plc and hitech screen pws 6300 s i use twido soft v 3.2 and ADP V 6 for the...
8,608
181
170
129
