Need Locking Switch recommendation
Martindag
Sep 2009
quebec
227
Heya guys,
I got few mixing tank that i need to add safety on their door to make them safe
and was thinking the best solution so far would be some Guard Locking Switch and the only brand i used so far are the one from AB like the GD2 the metal one heavy-duty.
But i was wondering if you guys knew any other product from other brand or similar that could do the job better, i need something heavy-duty.
It's gonna be used with safety relay also
Thanks !
+1 for the fortress locks. They are super robust and the key exchange system is intrinsically safer than most.
The newer AB slamlocks are an OK copy of that system but they are not as agricultural and they are more fiddly to use (tolerances are too tight)
These switch look very robust and good quality i will try to buy them if i got the budget Thanks for the recommendation
Ok so I got a for/rev motor with a prox on each side to denergize the output but it keeps going back and forth . This is my first time really want...
21
6,175
I have an old Sentry Palletizer (S/O Number 3007 / Serial Number 1172) that has lost its program as the backup battery died years ago. I can...
47
63
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
304
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
356
