Need Mitsubishi FX2N processor help
bginer
Aug 2006
Georgia
30
Gentlemen,
I have a customer with a machine controlled by one of these processors which is approximately 8 years old. We had some problems, now resolved with a thermocouple card last week, and it got me thinking about the age of the processor and how there is no EEPROM backup on it. What I want to do is simply read off the program, and store it on a hard drive in case of processor faliure. I know nothing about the Mitsubishi line of PLC's so I went on line and got the following:
GX Developer-FX (the 1000 step version)
SC-09 cable (well an OEM replacement from E-Bay)
Every manual I can find
Everything looks pretty straight forward, but what I need to know is if there are any little 'undoucmented features' that I need to be aware of before I attempt this. Hopefully there is someone on this board that has experience with this line of PLC's. Hell, if there isn't anyone here, I'm screwed! :)
Thanks in advance,
Mark
Hi Bginer, although GX isn't the greatest software in the world, it isn't to bad when it comes to uploading. When you connect in with the SC-09 cable go to the On-line tab and Read from PLC.
Do a connect test and it should then see you FX PLC model. When it gives you the option to Read from the PLC you will be required to tick a few boxes of the items that you want to upload such as Program, Device Memory etc. Then go OK. It will then upload the program. Like most PLC types it will only give you the Bit addresses i.e X's, Y's, M's and D's without any labels\comments if you don't have a current labelled off line program. In general haven't seen any "curve balls" that might throw ya.
Phew!
RPax,
Thanks for the information.
I absolutely hate going to a customer site and trying something I've never done before. I have enough opportunities to look like an idiot in my life already! Thankfully the customer has ordered a spare processor so I will have the chance to 'play' a little bit before I access the working processor. Nevertheless, you have eased my mind a bit.
Thanks again,
Mark
It is a good idea to tick all the boxes, this will ensure you get the data stored in the Data Memories just incase they have stored static values i.e. timer values in them (very often used with HMI's).
Sometimes they will store the comments in the processor but as this takes up a lot of memory it is usually omited.
upload is simple just setup communications & test connection then upload processor, tick boxes for the upload required then save the file.
nothing could be simpler.
Also, it will have no documentation associated with the program. If you can't this from the OEM, at least add comments to your I/O in the program off of the electrical schematics.You should also get a replacement battery F2-40BL
Give us a yell if you run into a snag
Marc
@parky & Marc,
I appreciate you taking the time to give me some more information on this. Good advice is always welcome.
Thanks Guys,
Mark
I think you are talking about the 1000 string download from Mitsu's website? Thats ok and will work for you but keep in mind if its more than 1000 string ladder you wont be able to see anything past 1000
I have a Mitsubishi FX2N-64MR-UA1 processor. The 1st analog output card is an FX2N-4DA. It requires 24VDC power. That card is obsolete. The card...
1,595
Hi, Complete novice on PLCs and need your help (again). On GT Designer3 what sort of button/switch do I need to add to Start/Stop a water pump...
1,992
Hi, Can someone help me out? Please excuse my terminology because I'm a complete newcomer to PLCs. The PLC at work is modular/expandable and...
18
4,073
Hello I am new in Mitsubishi PLC's so I have a request to convert a program which is running in a Q06H CPU to the same machine but running a...
2,005
Hello, I have an old machine I'm trying to get reloaded for a customer, and it has a FX2N PLC in it. I have a copy of GX Works FX, but the...
1,771
