Need PLC program converted to PDF
Here you go. I split the files due to file size limits.
P.S.
@ Mickey,
I believe your files have some LAD files missing.
I have a Micrologix 1500 LRP24BWA . I also have a 1784-PCMK/B card I would like to use with it. What cable do I need to connect from the PCMK to the PLC? I have a cable we used to connect to PLC 5s that is a 1784-PCM5/b. It doesn't seem to fit in Comm port 0. I do have an RS232 port on my computer. I have another cable we used for PLC5s that has a 25 pin male D shell connector on one end and a 9 pin female on the other. No number on it. There are 8 pins on the 25 pin connector used.
i'm too young for the plc 5 advice but if you have an RS232 port on the SLC you should be able to direct connect using just a null model 5$ serial cable ?
The 1784-PCMK/B card is for DH+ and DH485 communication. Your ML1500 has 2 serial ports, you do not need the 1784-PCMK card to communicate with your ML1500. Your processor has 2 serial ports one 8 pin one 9 pin. Simply use a null-modem cable from your computer to the processor. See PDF below for more on the cables.
The cable you have is for DH+ networks, it's a good thing it did not fit you could have damaged the serial port on your ML1500.
Disreguard the last question. I have SIMULATOR. QUESTION. I have a used 1500 I would like to train on. It had 4 I/O modules connected to it. Processor plus sub base no 1764-24BWA. Will I have to configure the I/O to just use the processor and sub base? How do I do that?
I will be designing an automated hydrostatic system. The system on paper works like this, a plc like the click will get information from an hmi...
227
43,275
Hello. I am working on a PLC program that needs to check input 1 after timer two is complete to see if a valve can close or not. Below is the flow...
2,840
I am used to working with Allen Bradley PLC's and their Rockwell RsLogix programming software. I have a product I'm reverse engineering that has...
5,877
Hey everyone, I'm currently in my last year of high school and I have to automate a scorebord for a foosball table using 4 optical sensors (sender...
38
6,366
I have received Micrologix 1400 plc as a replacement of Allen Bradley micrologix 1000 from my vendor. Now i need to download the program through...
5,448
