There are at least two ways to configure your I/O. If you can go online to the MircoLogix 1500 PLC, then go to the left project tree, select "Project, Controller, IO Configuration", then "Read IO Config".
The Auto-Configure only works if you are on-line with the PLC. If you need to do an off-line configuration, you go to IO Configuration and manually select the Input and Output modules (THAT ARE INSTALLED) from the "Current Cards Available" list.
With NO Input or Output cards installed, you will get error messages when you try to use I/O that is not shown on your I/O Configuration list.
