Need Profinet explanation please
Ahh I see,
The Remote IO will be ready in the field. I need to plug into the network that they are on to do commissioning and add them to the project.
I guess I can't do it like I'm used to from Rockwell where I can sit at my desk add field equipment to my project.
Ahh I see,
Well, you CAN do it at your desk. Instead of using the handy dandy auto detect feature, you manually create the device. You find the correct part number/FW in the HW catalog, create the device, give it the correct device name, etc.
Most (but not all) PN devices get their IP address from the PLC, so you usually don't need to worry about assigning those in the field, just the device name. Note that assigning the device name DOES need to be done while you're plugged in out in the field, for the initial setup.
I have a device that is connected via modbus to a modbus-profinet converter, and then to a scalance switch. I have no idea how to establish...
1,793
First time ever doing profinet or profibus or anything on a siemens. I've only ever used discrete IO with it. So when I add a servo drive to the...
3,269
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
187
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
342
169
