What devices need a GSD file / Modbus to profinet
plcnoob69
Jun 2023
Nigeria
30
I have a device that is connected via modbus to a modbus-profinet converter, and then to a scalance switch. I have no idea how to establish communiation with this device, I tried searching for GSD files of the device and the modbus-profinet converter but can't find any... Maybe I don't need these devices in my hardware configuration?
If that's the case, what do I do, how to even start? I read the manuals but they don't talk about this.
My understanding is, yes you do need gsd/gsdml files. I do not know another way to do it. Otherwise the PLC can not communicate to the device.
Some websites do not let you download the gsdml files unless you register and log in to the website. For example, Control Concepts and IFM make you register and log in, as far as far as I remember.
What is the device? How old is it?
If you can't find the gsdml files online or in the manual, call the manufacturer. It is their job to supply users with gsdml files so
What is the device? Maybe someone else here has used it
I just had a project like this... Used these device per the customer.
Prosoft Gateway PLX51-PBS
https://www.prosoft-technology.com/...IP-Modbus-R-TCP-IP-or-Modbus-R-Serial-Gateway
You can generate the GSD files needed to make this work using the configuration utility software.
Their help is a little Janky when it comes to setting up profibus to Modbus comms, but basically you'll need to create those modules that the profibus setup will see as virtual cards and internally Map them to modbus registers in the configuration utility.
It will probably take you a bit of time to get it working exactly, but it does work.
This device could be an alternative for you.... What device are you using currently that's giving you problems?
I am going to daisy chain a couple Modbus devices off of a Click plc using rs 485. There will be three slave devices daisy chained off one another...
9,192
Hi people! have to acquire data from 4 flow meters of steam (SITRANS FX300) on computer, they have HART protocol, I searched but didn't find...
3,375
Hi, I want to build a demo station to test devices and programs and I need some help with it. I want to connect GuardLogix, Piltzmulti and...
149
I have a piece of equipment that is operated by a PanelView Plus 600 HMI touch screen via RS232 into a Micrologix 1500 PLC. I am trying to...
147
I have 9 field devices, three METSEPM5110 power meters and six ACE949-2 rs285 interface modules. I want to read this Modbus rtu data through rs485...
316
