Need recovery from Wonderware Intouch window maker starting error
azadplc
Aug 2013
18
hello... I can work in wonderware intouch window maker easily. But when i switch to Runtime(windowviewer) page, it doesnot open... or may error will come "could not start windowviewer" rarely. Please help me out friends..... My all work is pending for this error:sick:....please reply me as soon as possible... thanks in advance....
i tried
thank u fr ur reply. I tried a lot like that also... but no response.... if virus of systems will affect this process.... ?????only one project only doing like this.. others working properly...i don know the reason...
Just guessing.
Try;
..temporarily disabe antivirus software.
..insert WW Intouch CD and look for a "REPAIR" option.
..search for and delete a file named appedit.lok within the application directory files.
(although this files presense usually will not let you start windowMaker).
..start windowmaker/windowviewer from an administrative account.
..does this computer meet minimum system requirements for WW version?
Microsoft .NET framework 3.5 for WW ver. 10.1
..see antivirus system exclusions
http://esupport.wonderware.ch/Data/ReadMeIT101SP2P1.html#Top
Antivirus Software Exclusions
Configure your antivirus software to prevent archive files from being scanned. Also, antivirus software should not scan files in the following ArchestrA folders (ensure subfolders of the listed directories are also excluded): C:\Program Files\ArchestrA\
C:\Program Files\Common files\ArchestrA\
C:\Program Files\FactorySuite\ (may not exist in newer installations)
C:\Program Files\Wonderware\
C:\InSQL\Data\
C:\Documents and Settings\All Users\Application Data\ArchestrA From Application Server Platform objects:
History Store Forward directory: (if not default)
From Application Server Engine objects:
Checkpoint directory location (if not default)
<InTouch Application folder path> including:
C:\Documents and Settings\All Users\Application Data\ArchestrA\ <SMCLoggerStoragefilepath>. The default is:
C:\Documents and Settings\All Users\Application Data\ArchestrA\LogFiles\ SQL Server database files of type:
.mdf
.ldf
Hi everyone..... Whenever I started to open the Intouch software, after selecting my intouch file the error has been come frequently. That is...
2,980
50
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
282
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
347
173
