need rsview32 help
rstead
Dec 2009
Edinburg
Have a runtime application of RSView32 on a plant floor box. Developled by a 3rd party. Do not have development license and am tired of paying the Rockwell price. Need to add a new tag to the data logging on that application and change the report viewer layout to accomodate for this new tag as well. I understand that the report viewing, print, etc. are done in VB. Can i modify the report viewer layout in VB and can I modify the data gathering file that I need to add the tag to in any other way than buying the development package?
Do you know how many tags you have? The two hour trial will open and work but I think it is limited to 65 tags or less which I assume it won't work for you.
Also, you could contact your local Rockwell people am I would assume they would help you on just a tag or two.
Hope this helps
Hi, every time I open my rsview32 project it gives me an error "fails to update Source DSN" I have a hunch it is because I am using windows 7 64...
4,427
Hello, I'm a new user and i need help with a project... I got a micrologix 1500 plc. I made an easy program which includes a timer, and i got a...
1,524
We have a data field we have to keep updating and i thought it would be much easier to use excell and then import the data from there so rather...
2,168
Hi "Unrecognized DTSA Structure". Has anyone come across this situation.I have a SLC5/05 with a program in it, but since some of the I/O cards...
11,329
Hello. I have a job where I have to juggle between several RSView32 programs. Whenever I close out of one .rsv program (properly) and try to...
2,089
