Need Help on RSView32 & RSLinx Communication
nirmal
Jan 2003
17
Hi
"Unrecognized DTSA Structure". Has anyone come across this situation.I have a SLC5/05 with a program in it, but since some of the I/O cards have not been placed in the rack it shows faulted condition.
When the RSLinx Who is used i can see the processor, no probs at all. Now when i Use RSView32, I created a TCP/IP Channel since iam using a ethernet with a switch for the communication. Gave the AB_ETHIP-1 asa the primary driver.But when i go to the Node option and try to select the station, I can see the processer with its IP address, but when I select it I get a Message box saying"Unrecognized DTSA Structure". Can anyone tell me what that means and the remedy for this.
Thanks a lot
Nirmal
Yeah. Been there already and did it, but the problem still persists. Someone else suggested that i use the OPC Server. Frankly iam not an expert in PLCs. Read some Help Files and tried to do it. Created a Topic in OPC/DDE communication Then went to RSView32, didnt create a channel, went to Node and created a In process node for RSLinx OPC Server. Now when i had to allot addresses for my tags, it went to the OPC Address browser. I saw the Topic there. It expanded to offline and online when clicked upon. Beyond that I couldnt proceed anywhere.
Can anyone please help me on this. When i started working on the project the PLC hasnt arrived and so i gave all the Tags as memory tags. Now I have the PLC and when I want to allot Device addresses I face all these problems. :(
Unrecognised DTSA structure
I have the same problem with RsView32 6.30 w/ RsLinx 2.41.
I'm using Direct Driver ETH-1
Any developments in the solution on that problem?
BGR
fox
Hi, every time I open my rsview32 project it gives me an error "fails to update Source DSN" I have a hunch it is because I am using windows 7 64...
4,427
Hello, I'm a new user and i need help with a project... I got a micrologix 1500 plc. I made an easy program which includes a timer, and i got a...
1,524
Have a runtime application of RSView32 on a plant floor box. Developled by a 3rd party. Do not have development license and am tired of paying...
1,827
We have a data field we have to keep updating and i thought it would be much easier to use excell and then import the data from there so rather...
2,168
52
