Need some help about order solenoid valve in S7 GRAPH
tyobes
Apr 2017
UK
Hello
I'm new here and also my english is little bad bad I will try to explain my problem
I need to do a program in S7 GRAPH which controls the opening of the solenoid valves (SV) which are distributed on 4 pressure switches, there are 5 solenoid valves in each pressure switch(P).
I need to open one SV in each pressure switch (1,2,3,4,5) at the same MOMENT, but if for example pressure switch 1 (P1) is breakdown, this should not affect the operation of others, I need to open just one SV in each pressure switch Which are still available, another example, P2 and P3 is OFF but the others is ON so I need to open just one SV in P4, P5, P1, and not touch or open SV in P2 and P3 because they are breakdown (OFF).
How I will do this, I thought of the interlock or a branch OR but is a lot of cases to do if I use branch OR.
Awaiting your help
Thanks in advance :)
I'm fairly new to Rockwell software, I've had some basic training in the past but nothing too advanced. My company and I use Reliable products for...
342
169
Good day all! Can someone help me with the procedure to update Beijers E700 firmware? The Panel I am working on is firmware 2.04v and I would...
71
Hello nice to meet you, im new in here, I'm currently trying to convert code written in STL for a S7-400 to SCL for an S7-1500, because when i run...
320
