Need to Interface Delta PLC with Delta temperature module
ssana168
Jun 2011
Pakistan
38
Dear all,
I have below mentioned items,
1. Delta PLC DVP24Es2
2. Delta Thermal Module DVP 04TC-E2
3. Thermocouple Type J
Now i need to interface PLC with thermal module. Can anyone tell the instruction set to see the "Present value of Temperature".
What you're asking for comes with some Technicalities if U're newbie in Automation.
I feel you may need to get a specialist to assist you in the initial set up. So U could learn it with ease afterwards without work pressure. Just my opinion anyway.
I've inherited a project that has 5 ea. Wago 750-881 controllers. Each one is connected to a Yokogawa DX-1000 paperless Chart Recorder. The...
2,472
I want to have some feedback about the MESInterface IT from Mitsubishi. I have never use mitsubishi stuff and we might merge to them. I read...
2,579
Hi friends I am doing my major project and I need your help in writing a Ladder logic plc program. My project is to detect the edges of a block...
4,821
Hi Guys, I need to interface to a Current Injection kit via RS232. I have a Control Logix L61 rack with a 2 spare slots should additional...
2,639
G'day, I'm trying to find a definitive answer to the following. If an IM365 interface module is fitted in an expansion rack can a power supply...
5,872
