Need to move an AB SLC 5/05 processor programming to the new ControlLogix 1756-L55
piscis
May 2003
241
How difficult will it be to move an AB SLC 5/05 processor programming to the new ControlLogix 1756-L55?
We have an application already written with the 5/05 that includes Analog Inputs and outputs and discrete Inputs and outputs.
Can anyone share some comments about the options available for doing this?
Is there a reliable converter? Would it make more sense to re-write the whole thing? Would RSLogix 5000 be able to open an RSLogix 500 file reliably?
There's a converter built into RSLogix 5000.
However, the results are not perfect, and do not do justice to the CLX platform.
My inclination would be to re-write.
Hi there, I have a new Simatic S7-400 with CPU connected to a rack of 2x ET 200M (IM 153-1) terminals which supply 4 x I/O boards each. I have...
1,710
I am using a 1771-SDN Devicenet module on a PLC-5 I have it in slot 0 but need to move it to slot 1 of this group. Because I am adding a E-Net...
1,727
Need help on EV Move utility for activation key using ICOM version 6.19 for PLC2. I am converting a PLC2/17 to a PLC5 and have a dieing DOS PC...
17,518
73
132
