1771-SDN need to move to slot 1
thunder
Jan 2005
VA
I am using a 1771-SDN Devicenet module on a PLC-5 I have it in slot 0 but need to move it to slot 1 of this group. Because I am adding a E-Net module to the 5-60LB controler. But when I move the devicenet card the slot information box in the programing software is grayed out.
It has been a while, but check on the slot addressing for the
rack. I think some of the smart module ie 1771-SDN will only work
in single slot mode.
AJ
Hello, I am setting up for practice and I am having trouble seeing the 1771 Scanner in RsLinx as well as Rsnetworx My setup: slot 0 : PLC-5/40E...
985
Hi, Whats yours thoughts or experiences on buying used PLCs parts from Ebay? Had any success? I need a 1771-SDN Devicenet scanner to add about...
4,066
We have an Allen Bradley Powerflex 70 Device net drive connected to PLC5 1771-SDN module. The replacement drive is a much newer firmware so I need...
2,616
Hi, I have to use a 1771-SDN devicenet card for a remote control panel which is controlled by PLC5000. Now, it looks like 1771-SDN is used for...
19
3,706
I have now 2 scanners that have the RED light Fault lit.. It has been put on the back burner and not an immediate FIX... The first one was fine...
2,127
