Need to send STRING to HMI
Tom, good point. I guess I am assuming that he is not using inTouch anymore, otherwise why change? I typically do the same thing - let the HMI manage the display interpretation for the data. I am OK with bulky HMI code, as long as the PLC is efficient.
If you have three messages in tags STRING[1], STRING[2] and STRING[3] then set aside another string (HMI_STRING)which the HMI will read.
In the PLC code use COP STRING[1] HMI_STRING 1
Note the '1' as the length in the COPy command. You are copying one string.
And you can save some memory by making HMI_STRING an ALIAS tag, aliased to STRING[0].
Note also you can create your own STRING data-types : the pre-defined one allows for 82 characters. If you have an upper limit of, say, 30 characters, create a STRING30 data-type. Use this UDT for HMI tags that are limited to 30 charcters.
I have a 120V signal coming out of this hardware to go to something, which can either be wired or wireless on its own network or connected to our...
3,604
I'm looking for documentation for the functions PDAT_CY, PCD_SEND and PCD_RECV that are part of an existing Step-7 program. The best I can find so...
2,394
Dear All, I have a project with SLC 541 and RSView32. The client want to send alarm massages (SMS) to mobile phone. Can anybody advice me the...
3,204
46
I've got this 3-phase 575V motor that we're controlling with a VFD (Variable Frequency Drive), which has been quite the learning curve in itself...
280
