Negative polarity Zener barrier
HANYWEPCO
Oct 2009
UAE
For negative polarity Zener barrier , the cathode of the zener diode is connected to ground...So how this circuit work for DC supply?? as per my understanding ,by this connection type then the zener diode should be acting as a normal diode and all the current will go through it and no current should go to field!!! please anyone can explain for me especially I am using one with dual channels to supply smart positioner , should I select positive or negative polarity zener barrier ???and why???
a zener diode is a normal diode that will break its blocking at a certain voltage. The problem is the wattage as all this energy, need to be dissipated. so in most cases a resistor is used to lower the amperage.
Negative polarity for NPN output circuits, where you would want the negative side fuse protected.
You are correct about how Zeners work. Select a positive type for your application, and wire it so the Zeners will not act as diodes in normal operation.
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
62
I am troubleshooting an actuator which is not responding to the plc code. The range in the channel of the Allen Bradley 1756-OF8 Analog card is...
628
I have 3 koyo PLC's in series. The 1st and 3rd are reporting values correctly but the 2nd is reporting negative values. The values in the PLC and...
1,419
Hi, I am connecting an Autonics make stepper driver type, MD5-ND14 to a Kinco PLC (K205 series) this has a sourcing output which cannot be...
1,116
Hello. I am trying to figure out how to setup a PID in Control Logix 1769 Controller in a way that it would control a drive speed by sending...
1,619
