Network Address Translator
apolionman
Nov 2013
Dubai
47
Hello Guys, Happy New Year. 🍻
I just wanted to ask regarding with NAT device switch/hub/router for PLCs & HMIs connected in EtherNet/IP.
We have 1 line of machine which is inter connected with each other and we are planning to brought up this machine in our Factory Network level.
We already assigned IP addresses in Factory Network for each machine and we dont want to change the current machine IP address on the line.
For Allen Bradley system we find it easy because we have AENTR modules that will allow us to translate private IPs and public IPs.
"We tried this AENTR module in different system, the good thing is IP address is readable but the bad thing is it cannot be translated."
We have 3 machines which is running in Schneider PLC - ELAU Packdrive c600 and HMI - SIMATIC panel M377 15" touch.
Can you suggest any other NAT devices or modules that is compatible for all?
Thanks! a lot in advance!
I have a process network connected together with N-Tron unmanaged switches consisting of two CompactLogix PLCs, a 1794-AENT remote IO rack, two...
4,572
I am trying to create a network setup that would take many devices that are working together and have them appear as one device or IP on a network...
2,285
Hello, I'm adding devices to the existing ring network - AB Device Level Ring (DLR). Can you please suggest if having all of the devices' IP...
3,074
Hello. I want to know if there is a way to tell if someone is online with a PLC from an specific IP address. To elaborate my inquire: there's a...
5,075
Does anyone know the default IP Address for a new 22-COMM-E Allan Bradley PowerFlex Network card? It was not listed on any of the literature or...
5,617
