Default IP Address for 22-COMM-E AB Drive Network Card
Mar 2016
Raleigh
88
Does anyone know the default IP Address for a new 22-COMM-E Allan Bradley PowerFlex Network card?
It was not listed on any of the literature or paper work that came with the card.
Allen-Bradley Ethernet devices don't use a "default" or "fallback" address.
Out of the box, they're set for DHCP or BOOTP so they can get an IP address from a server utility. That feature is generally then disabled and the devices are set for a static IP address.
Many devices store the IP address in their onboard nonvolatile memory; the 20-COMM-E and 22-COMM-E and 1756-ENxT and 1734-AENT modules are good examples.
Some devices store the IP address in the user program configuration itself; the old SLC-500 and PLC-5E and MicroLogix 1100/1400 are examples.
Thank you for the reply. I am trying to use Rockwell Automation BOOTP server to set the static IP address on a replacement drive and 22-COMM-E card. The problem is when I launch BOOTP there is nothing there. I assumed my PC had to be on the same subnet/ip address range as the com card.
Do I need to cycle power to the drive to see it in BOOTP server?
I've inadvertently tick the DHCP box in the sick software and uploaded this in the PLC (Sick FX0-GENT) and now i am unable to connect to it. Is...
999
Does anyone have handy the default Ethernet IP Address of a 5HP AB Powerflex40 drive. The plant wants to add it to a network I am currently...
1,926
Anyone know what the default IP address for a 5/05 is?
11,803
I am working with Twincat 3. I am trying to store some images in files and when PLC restarts I want to read those files and get the images...
53
Hello all, I am looking for a way to have a user get logged out after an X amount of time because to default so that user privilages are no...
595
