Network newbie question.....
jb35sport
Sep 2013
Tampa
We are looking to possibly integrate a PLC (500 or 5000 platform) into existing relay controls on three PVC extruder lines and would like to add a Panelview Plus 1000 as the HMI interface.
We are looking for added functionality.....things such as hours log, faults, data logging, and other I/O interface.
We want a cost effective way to approach the project.....Can we effortlessly network all 3 processors and the HMI thru a switch and then read/write to the various processors?
Do you think Allen Bradley is the best route for this or would you recommend looking into cheaper alternatives such as Automation Direct or Red Lion for possible solutions?
Thanks in advance for any feedback provided!
Jb35sport
I think it is doable and 1 HMI will work for all 3 extruders
But if I were doing the project I would insist on at least 2 HMI running the same program on both in case you have a problem with one you can use the other. As you are aware you can't just stop a PVC extruder they have to be purged anytime you interrupt the flow.
It looks like an interesting project
Hello, y'all! In order to connect the control network from a central room, what version of FT should be used on the PCs? Thank you very much!
2,224
Hello, I have a A.B Compact logix communicating with two fanuc robots via ethernet. The plc also communicates to an automation direct hmi screen...
425
So I'm pretty new around here but I come looking for advice or suggestions to research. Im the plant electrician/SCADA guy for a warer department...
274
Looking for a supplier of Layer 3 Network Switches DIN RAIL MOUNT, in Alabama, In the UK we would use Typically in the UK we would use...
214
We are having an issue with some servers, with "Teamed NICs" is we plug one cable leg of the team into one switch and the other to another...
71
