networking SLC 5/03 & PLC5 oops
jimtech67
Jun 2002
New Jersey
507
I have 5 SCL 5/03s not networked to each other but each is connected to a PV100 using DH485. And 2 PLC 5s not networked to each other but communicating to their own PV900 over DH+.
I need to network all PLC to an RSView station. I know I can create 2 networks one DH485 with 1747-AIC cards and the DH+ network is simple.
My question is there a way to get all PLCs on Ethernet? What hardware do I need for the SLCs and PLC5s. I do not want to change the processors to 5/05. I know no solution will be cheap but if it is better I think I spend the money.
thanks all
A DH485 network with 5 SLC5/03s and 5 PVs and 1 RSView PC would be quite limited in performance.
Only "cheap Ethernet" way is to use 1769-NET-ENI modules to connect to each processors serial port
(channel 0).
But there are issues with the low performance of these modules.
For the PLC5s you could attach a 1785-ENET "sidecar" to each processor.
G
I have 5 SCL 5/03s not networked to each other but each is connected to a PV100 using DH485. And 2 PLC 5s not networked to each other but...
2,387
I have a SLC 5/05 that I am wanting to access some data in a ControlLogix PLC elsewhere on the network at our plant. I thought I knew how to do...
1,598
Howdy. So I am trying to create a small network of just 2 SLC 5/03's and my programming laptop. The SLCs are connected via RS232 to some...
1,889
I am looking into networking some Allen Bradley SLC 504 processors using DH485 (Blue Hoose)cable. At each end of the connection I will have two...
23
10,363
I have a slc5/05 and a main computer station that commuicates with ethernet. In another room, I have 3 slc5/01 that are independent of each other...
17
3,621
