SLC Networking
dc75
Nov 2007
indiana
I have a slc5/05 and a main computer station that commuicates with ethernet. In another room, I have 3 slc5/01 that are independent of each other and not networked. Each one has a touch screen HMI....
What I want to do:
I want to network these 3 5/01 using DH-485 and communicate with them via our slc5/05. I think this is possible, but im not sure of the hardware I will be needing.... Any help will be greatly appreciated...thanks
Yes, I would like to keep the HMI's functional if possible...Another question, Would i need to just do away with the ethernet, and just have a DH485 network, or can i keep communicating to the 5/05 with ethernet??
If you look on the network diagram linked, there no reason why you can't still communicate to the 5/05 via ethernet. 5/05 connect the the DH485 via the link adaptor through the RS232 port.
With what you describe above, I personally would be looking to see if replacing the Slc5/01, with a Micro Logix 1100 could be the better option.
That way your network comms are ethernet, and most likely the HMI screens could still work with the other RS232 / 485 port available.
Give us the brand and part number of your HMI
A much easier option would be to replace the 5/01s with 5/05s. Don't have to replace any of the I/O. Don't have to recode anything. Pull out the 5/01, insert 5/05, "recompile" the program as 5/05, download. Done... 5 minute job.
Do you know the price of a 5/05 CPU. I like the 5/03 but the 5/04 and 5/05 are priced outrageously high
A 505 is approx $3500 CAD, a 504 is about $1700, and a 503 is about $800.
You can ebay them if you wish, there are other surplus suppliers as well, depends on your company, the current situation....etc.
There is always another way...
Connection from your SLC5/01 and 1747-AIC has different options see PDF below.
The connection from your SLC5/05 RS232 port to your 1761-NET-AIC+ should be a null-modem cable ( 1747-CP3)
ok, i understand... so my hmi should work like this? as long as my nodes are different of coarse??
OK, ive thought about this, and i think that this may be an even simpler way to do this....dont mind the elementary drawing...lol...i can keep my ethernet network intact, and just make a new network for the 5/01's....I would just have to configure the appropriate driver in RSlinx. right??
I have a SLC 5/05 that I am wanting to access some data in a ControlLogix PLC elsewhere on the network at our plant. I thought I knew how to do...
1,596
Howdy. So I am trying to create a small network of just 2 SLC 5/03's and my programming laptop. The SLCs are connected via RS232 to some...
1,888
I am looking into networking some Allen Bradley SLC 504 processors using DH485 (Blue Hoose)cable. At each end of the connection I will have two...
23
10,353
Hello, I am an EE student currently working on my senior design project that involves using 2 plcs networked to add more I/O. Right now we are...
2,155
everyone i have a new slc 5/05 processor to configure . i have the choice of using bootp or calling my network admin to get settings for a...
2,021
