best networking method for slc 5/05
MNJ96
May 2005
Salem, Oregon
50
everyone
i have a new slc 5/05 processor to configure . i have the choice of using bootp or calling my network admin to get settings for a static ip address . which way would be best and why .
thanks in advance
phil buchanan
I would just set up static IP address and gateway from IT Dept.,although I have never used bootp so I can not comment on its use.
BootP is just a utility to assign an IP address.
Your processor needs an IP address. You need to obtain one by calling IT and asking for a static IP address and then manually connecting serially and assigning the IP address your IT department gave you.
Or, you call IT and again ask for a static IP address. Then you use the BootP utility to assign that address (instead of using the serial connection to accomplish this.
Either way, you need a static IP address.
Now, as an alternative, if you want to avoid IT altogether and create your own private network, then assign your own IP address, again either using the serial connection or via BootP. Just make sure that your IP addresses you choose do not conflict with the plant network.
OG
Just wondering where you guys think the best place to get training is? Considering, DCS, Networking, PLC Programming - Micrologix 500/5000...
2,660
I'm venturing into the world of PLC networking and hoping that some of my questions can be answered here. We have a process with one ML1200, one...
4,870
Compactlogix controller, program has 28 conveyors that use TON's to start the conveyors. The TT sounds a warning horn during start and the DN...
499
I have S7 1512C controler for controlling 48 PID temperature loop, the output is PWM. Please I need the best, most efficient way to write the...
612
I am going to need to use HART multi-drop in order to handle a series of Vega Radar units. There are a lot of options and I'm wondering what...
260
