Good Morning ,
I purchased a new CompactLogix 1769-L18ER-BB1B. The last CompactLogix L18 I bought last year this time, I had no problem setting up. The sticker on the Controller reads.......
"This series B Controller requires firmware version 20 ( 20.014 and later), 24 or later. [/U]Verify that you are using compatible firmware revision. Failure to
do so will result in the inability to program the controller."
I went to download the latest firmware , and it says it downloaded correctly. But when I go to Control Flash the CompactLogix L18 , I see no
firmware in the "Select the new revision for this update" window.
When I go to download the firmware , I am downloading it to .....
C:\Program Files (x86) \Control Flash.
This is what I have at the moment on this laptop
RS Logix 5000 Ver. 20.01
RS Linx Classic Ver. 3.71
Logix Designer Ver. 21.00
What could I be doing wrong ? I am using a USB cable and I see the PLC in RS Linx . I should also be able to give it a IP Address by using BootP , correct ?
Thanks again , in advance.
