New plc 5-40
Try changing the Switch 1 settings to an unused DH+ station number, to see if the PLC-5/40 shows up at that node number.
Double, triple, quadruple-check your PLC-5 program to make sure that Channel 1A is configured for DH+. It should indicate that the Station Number and data rate are set by the Switch 1 DIP switch.
The observations you describe are consistent with a controller that is configured with Channel 1A set up for RIO Scanner, though I'm not sure why cycling power to the controller reverts to Channel 1A being in DH+ mode, unless the RAM backup battery is dead/unplugged.
210
the conveyor can stop because of a safety sensor or safety switch. And also it can stop because of an object jam detector sensor. If the conveyor...
189
Good Day to all of you, this is my first post, i will try to explain as best as possible, english is not my natural language. I am performing an...
42
252
I have a project to automate four generator sets. The system will monitor and store the load demand of the factory. Once there's Power outage, the...
64
