New Project and Need Help.
wdycus
Jun 2009
LA
Hello,
I was recently handed a project that someone else had been working on for over a year and could not get it to work. I have decided to cut our losses and start over with a solid foundation that we can work from for many years. This is a small part of a very large system that requires that the PLC functionality be synchronized with the rest of the system.
Please give some insight into why I should use one PLC over another for the following system requirements: We need a Linux server to remotely control a device(PLC)that opens and closes relays(5)on command and monitors toggle switches(3)and buttons(4)activated at a remote location via an IP backbone. The PLC must be extremely reliable, remotely programmable, and remotely monitored for a 24/7 operation. I am looking for something you would consider the industry standard and could be scaled and maintained for many years without loss of parts or service. Also please give some insight into network communications protocols. Is there a standard and do I need a server. There will be around 150 nodes. Is that an issue? Is there a standard software development platform and do I need anything special to program and configure the PLC. Your help would be greatly appreciated.
Thanks,
wdycus
The Rockwell Automation ControlLogix PLC would do the job for sure. It has Ethernet communications built in, so could accept commands from a remote Linux server. It has been around for many years and will probably be available for many more years.
There is no single "industry standard" because there are many competing brands and models. There may be a solution that is less expensive than the ControlLogix. You should consider also which brands have support available at the remote location. If there are no local business that provides service, parts, and programming for a particular brand (and you have no in-house talent), then that is a big negative for that option.
...do I need anything special to program and configure the PLC?
Wow!, I'll say you do! You need the programming software package for whatever brand and model of PLC you decide to use. You cannot program one brand of PLC with the software for another brand - they are not that flexible because of competition. It sounds like this is a new function for you, so you will probably also need some training on how to use the software to write a program.
What industry are you in?
I would highly recommend bringing in a consultant to either quote the job or give you the direction that you need. Your company has already burned a year on the project with no results, time to pay the dollars to a firm that can get in done for you in a few weeks so you can start seeing ROI.
The only way you'll be able to have a solid foundation is to begin with the experts in the field. This site is full of those, however posts on a forum won't give you the solid foundation you are looking for especially if the system is part of something grander.
Thanks for your feedback.
I agree with you 100%. That is why I am here to learn. One of the PLC training professors I was talking to recommended that I go to this site to get a different look at this problem. The original project is a much larger system that is using in-house developed circuit cards to do the PLC type functions and it was controlled via rs232 commands using an in-house developed communications command set transmitted over many miles to over 100 locations and has to be synchronized with data and voice from the system. It was transferred via DDS leased circuits. The new system was being developed totally in-house and must use IP over T1 transport. Our lead hardware designer and imbedded software designer both just left the group with a design that has a major design flaw that was discovered only a couple a weeks before we took over the project. Therefore we have turned to COTS off the self products to provide the customer with their system that they want on time. At this point I have been working with many engineers and technical staff before going out for hired help to determine the path to take. There are many sales people that say their equipment is the best and that they are the industry leader, but people like you that work with the equipment know better. I really appreciate the insight that is provided and your thought that this could be done much quicker than trying to develop it in-house at this point.
Thanks,
wdycus
Yes. Many networking and software solutions are not designed for that many nodes. Whatever you decide, you must doublecheck that you dont hit a hidden limit somewhere.
There is also the issue of scale. There is a big difference in designing and maintaining a system consisting of less than 10 stations, and a system with 100+ stations.
Your device may possibly be an "RTU" rather than a "PLC". Maybe there is an off-the-shelf device already.
[..]and has to be synchronized with data and voice from the system.
This part you must explain more.
Hey guys, So I'm working on a new project adding an HMI and need some help. So far what I figured out is I'm going to buy a large 85" LCD TV hook...
1,812
Hello! I need your assistance with the following issue. I need to upload project from 1756-L63 (v19.11) B Series controller for further diagnosis...
7,884
What am I doing wrong? This is a project for school and I thought I had it until I added the JMP/LBL instruction set to work as a loop. When I...
2,120
Hi people. I am from australia. Doing a plc course using siemens plc"s . Got given a task to design a pump cycle using two motors etc. The format...
2,796
I need a Programmable Logic Controller for my FYP. I've no such exposure to PLC just have studied that subject. I want a PLC that is easy to...
4,083
