PLCuser, I checked out tri-plc's web-site. Their stuff looks good.
I also checked out Entertron's web-site (pinworm) and their products actually seem very good, and a lot like what I need. Do you use Entertron PLCs?
I was looking at Automation Direct, but some of the literature on their web-site is steering me toward the Entertron equipment. It seems smarter and more flexible. Though there were no prices listed, which makes me think they are spendy. The AD was good because I could get what I needed for testing purposes, 20 I/O to one computer for a few hundred bucks.
As far as the size and topology of our project goes, in the end it's big. Meaning right now, I need 20 I/O going to one computer just for testing the software we are developing. The I/O is a small part of a larger system we are developing. The initial implementation of the I/Os will be over three floors of a hotel building, looking at about 150 room doors to see if they are occupied or not, based on switches by each of the doors. Those signals need to all go to the central computer, which gets all of the statuses of the doors and posts them as needed in our overall system. There are no predicted uses for a direct PLC output. For instance, right now, these rooms are monitored with AD PLCs which were put in about eight years ago, that show up in lightbulbs on several boards. Those are actual PLC outputs from what I know. In the system we are building, we just want all the data to go into our computer and we will handle the function of the lightbulbs in our system.
As far as RS485, USB, ETHERNET, ETC, I think ethernet is what we will use as it seems the most simple and compatible, unless there is some reason to use otherwise.
On another note, I did check out the OPCConnect/Java site. Thanks. That is good. With that I am confident that I just need to buy the hardware, and whatever it may be, we can easily solve getting the I/O signal into the computer. It is becoming more and more clear that there are many solutions to any kind of problem with I/O.
- Bret
