New to PLCs
satossa
Dec 2006
Ontario
I have just purchased an Omron ZEN PLC (10C1AR-A-V1). I have NO ladder diagram programming experience, and find the terminology foreign. All I want the PLC to do is to switch Q0 on and off to the following criteria:
On the RUN command:
1. ON for two minutes
2. OFF for one minute
3. Repeat four times
4. Wait eight minutes
5. Go back to 1.
Can anyone send me the ladder diagram for this? I have been playing with the ZEN for a couple of hours and I'm pretty sure I can get it (the diagram) into the unit. My problem is that I don't know what the diagram should look like.
Season's greetings to all and thanks in advance for any responses.
Try and visualize the schematic. You close a switch, it turns on a coil. You have a N/C contact of a relay in series so if the relay is on, the coil cannot close.
If you got the ZEN starter kit, the software and manual has some sample code.
I'm at a new job as the sole control engineer and trying to piece together where my predecessor left off. One machine I'm trying to get online...
101
Or there is an alternative to this? I suppose there are many but I've only seen put/get Can you for example set up a new plc and connect it to an...
306
I have a client who periodically experiences network communication issues. Sometimes when I VPN into the site, their SCADA systems will flash comm...
178
Hi, Seeking consultation on an implementation matter, and have a question about Modicon Compact 984 communication through RS485: Three Modicon...
224
