New year's puzzle: You are defusing a bomb
Not that I'm any expert on bomb diffusal, but if there are only two wires then cutting either one will kill the circuit, assuming no return path to the power source via the case (Surely even terrorists would follow basic safety requirements... )
After running into a machine wired exclusively with green wire it must be the best one to cut.
Unless the electrical inspector is there, in that case you better add another 5 green wires to be safe!
Ha ha!!
I would wire it all with black wire. And put a dummy DIP switch in to boot.
Dont cut the wires, maybe the circuit is fail-unsafe.
When you cut any wire, the bomb detonates immediately.
Instead, remove the detonator from the explosive.
The puzzle is:
Which wires go to the detonator?
Those are the only wires that can safely be cut.
Unless some jerk ran double or triple wires to it with your fail-unsafe.
How about wire it and pot it? [Pot is to encase on resin like some circuit boards are] Or fill it with Great Stuff insulation
Hi I've inherited an IFIX 5.5 application. A picture is enabled every now and then. I beleive its being enabled by a tag that is read from a PLC...
428
I have 15 wires coming from a black box sensor. I can't open it to look within. I know that two of those fifteen wires will comprise the feedback...
17
7,692
Find 3 palindromic numbers that, when added together, make 85709 (Numbers are in Base 10) Answers by pm please.
19
6,475
It was too early for Easter, suppose I could have done Chinese New year, but that's too close to Valentines Day. Two parts : 1. A Logix5000...
1,316
Another relative velocity problem, but non-linear this time. A quality control camera pivots (rotates) about a fixed axis to scan and inspect...
3,496
