Sensor lead puzzle
Good question, kalabel.
Yes, that's right. There are auxiliary analog outputs on the back panel. Your question leads right to the reason I'm trying to tap into the transducer directly, bypassing the manometer, in the first place.
The manometer is malfunctioning and is to be returned. But the process needs to keep running, so I can't just disconnect it and send it back without first being able to read pressure.
And that's why I'm looking to read the pressure directly from the transducer.
Also, I know the transducer is working because I have a spare manometer I'm able to connect to the transducer and it reads fine.
According to the manual there are two sensors one outputs 0 to 2.00VDC and the other 0 to 1.500VDC. nothing to directly indicate which wires are the outputs.
But in the instructions for diagnosing the sensors, the Pirani may be easier to figure out, by. The sensor has only four wires and to diagnose they say measure certain resistance value between two of them. One of the wires to be measured is -VDC and the other is signal, so you now have two pairs to choose from which narrows things down. The diaphragm sensors is more complex.
Hi everyone, I am working with micro850, a proximity sensor (FOTEK, PL-05P) and a 3DOF serial arm robot. I use MC_MoveRelative to control the...
62
Maybe a stretch to call this a PLC question, but it does connect to a PLC input. I have two German switches: Sick WL9LG-3P2232 And a...
113
Hi, Need help with coding for a faulty component sensor which we are using a push button as we are using a test rig. the plc is a allen bradley...
213
Hi all, I am implementing an incremental encoder sensor (ABZ) to replace the existing "manual" encoder wheel I have in my device. This is a 360...
170
I am looking for temperature/humidity sensor recommendations. Would like the sensor to display temp and humidity. Need to connect to a Contrologix...
232
