Newbie on PLC driven servos
Syphonics
Sep 2011
bedok
Hi all,
I am new to AC Servo. Currently I have with me a Yaskawa SGDP Servopack and servo. I managed to use the SigmaWin program to do JOG on my servo.
But I do not know how to connect it to my PLC and control it.
Currently I only have knowledge on Stepper motors on PLCs, which are pretty simple.
But how do I control servo using PLCs? Are they still the same as stepper, just by output number of pulses?
very little in a past life. As I remember, we used a 0-10v analog output (from Wago I/O) to an analog input on the servo drive. The analog cards and the servo drive were in the same cabinet for fewer noise concerns.
Then the servo drive was configured so that its speed reference (desired speed) was set by the analog input - there was some scaling inside the servo drive, and we had predetermined PID constants for the load we were running with it (a short conveyor belt). I'm not sure if it had an auto-tune or not.
It did have a few inputs required to run - I forget their exact names, but there was a 'ready' input that it needed and a 'run' input, this allowed us to change the analog signal without running the servo.
it had only 1 digital output which told us it was running and not faulted - this went away on a fault or power down - this was a little primative as it would have been nice ot have seperate bits for 'not running', 'in alarm', or 'unable to run' for more visibility. a fieldbus would have been even better =)
The servo motor itself was ordered with an encoder - not sure what type. the speed/position feedback was all taken care of in the drive.
Note that since this was on a conveyor, we never cared about its true position. We never found 0 degrees or specified a 'home' position - as long as it came to speed and changed speed quickly that was all we needed it to do.
It was very important to have the Yaskawa software to view and change paramters- you arent going anywhere without that.
-John
Hi, after 30 years involved with automation I'm actually writing my first PLC program and am struggling a fair bit. My background is mechanical...
1,889
I picked up a Siemens S7 1200 from a buddy and I want to start fiddling around with it to learn about PLC's. I don't want to spend a lot of bucks...
2,470
Hi Guys I completed a PLC course a few weeks ago and I've decided to build myself a PLC training rig. I'm using an s7 200 as I managed to pick...
3,143
Hopefully I'll have a legitimate copy of RS500 to program micrologix and SL500 series PLCs. A guy in another group is going to mail me his old...
1,841
I was recently given an FMD88-10 and AN20MA-2, in excellent working condition. I'd like to start learning to build PLC's, and just tinker around...
2,310
