Newbie PLC Question
Oct 2016
Aberdeen
Hi Guys
I completed a PLC course a few weeks ago and I've decided to build myself a PLC training rig. I'm using an s7 200 as I managed to pick one up cheap on ebay. The course didn't cover wiring a PLC just ladder logic. So far I've got power and all my push buttons wired in and it works fine. My outputs will be lamps that are incorprated in the buttons. So far i've wired nothing into my outputs at all, picture attached.
Can anyone give me advise on how to wire the outputs? I guess the first is to bring power to the outputs, is that correct?
Ally
Ouput Wiring
Those look like DC sourcing outputs. Below where it says "CPU" on the picture does it say DC/DC/DC? The complete part number would be helpful. My guess is that you would connect +24VDC to the "L+" terminal, and 0VDC to the "M" terminal. Turning the output "on" in the PLC program would then connect the respective output to +24VDC. The output can be wired to the indicator, usually labeled "X1". The other side of the indicator, usually labeled "X2" would be connected to 0VDC. Having the indicator wired with the correct polarity is only necessary if it is a unidirectional diode, a simple incandescent lamp indicator usually doesn't care which way it is wired.
As you are New to the PLC World, Id like to tell you to Read the Manual, as this will be common place once you are doing plc programmer regularily new to you hardware always leads to that. Lol
This. Download the manual, Siemens manuals have all the wiring info. This should of been your first port of call.
If your self teaching, reach for the manual first.
Hi would add the S7-1200 is fairly cheap and is more modern and relevant than the S7-200
No harm in training on the 200 of course
Thanks for all the input everybody. Turns out i was thinking about it all wrong. I'm not really an electrical guy more mechanical but i got it figured. I now have nice rig for me to learn on!
Thanks again!
I would recommend reading Allen Bradley manuals to learn on because the level of documentation is outstanding. Best I have seen in the business.
Automation Direct PLCs are inexpensive, software is free, and PHONE SUPPORT is free.
Documentation is decent but not on AB level.
Hi All, I've just recently completed a basic training course on PLCs. I've been playing around with Step7 from Siemens and I'm trying to...
1,830
Hey hows everyone? Ive been in industrial maintenance for almost 25 years as a mechanical tech. Recently I took an interest in working with our...
3,467
Here is a newbie question. Are DC power supplies used for any reason in the industries that use PLCs? This is not including any PLCs themselves...
3,737
Hello, I have a couple of questions and would appreciate any help from you guys. Im basically trying to learn PLC's by playing with them at home...
5,548
hi, I have a question. I have GE PLC and I need to write the application in C++ that will set the TBits on and off through TCP/IP. Can somebody...
2,835
