PLC newbie question
mike47
Aug 2012
GA
20
Hey hows everyone? Ive been in industrial maintenance for almost 25 years as a mechanical tech. Recently I took an interest in working with our PLCs. Along with schooling, I have a good mentor. My question is, today I got to deal with a PLC fault on my own. It was an AB SLC 5/03, and the fault was 0002h. It seemed like the processor couldnt see the #12 module but knew it needed it. I removed the #12 module and reinserted it and downloaded the I/O config. The processor fault was cleared and the line started as usual. Do I need to get ready to replace this module or rack or is this common?
Did your mentor have anything to do with creating this fault? I have had instructors test student knowledge of troubleshooting by inserting a small piece of paper on one of the terminals, then replugging the module.
It sounds like he trained you well and you passed the test.
Talk to your mentor.
Lol. He claims nothing but looks guilty!
"I see nothing, I know nothing!" - Sergeant Shultz
Another good tip to know is that you can clean the terminals with a pencil eraser (or similar) to remove any corrosion or film deposits.
Turns out that a tech, on the previous shift, changed out the processors powersupply which was bad. I guess somehow the processor got a little scrambled.
Hi Guys I completed a PLC course a few weeks ago and I've decided to build myself a PLC training rig. I'm using an s7 200 as I managed to pick...
3,146
Hi All, I've just recently completed a basic training course on PLCs. I've been playing around with Step7 from Siemens and I'm trying to...
1,831
Here is a newbie question. Are DC power supplies used for any reason in the industries that use PLCs? This is not including any PLCs themselves...
3,740
Hello, I have a couple of questions and would appreciate any help from you guys. Im basically trying to learn PLC's by playing with them at home...
5,551
hi, I have a question. I have GE PLC and I need to write the application in C++ that will set the TBits on and off through TCP/IP. Can somebody...
2,835
