shiggins0111
Hi All,
I have searched for an answer to this on other forums but didn't find anything, so pls be gentle if there is.
I am new to PLCs but enjoying the learning curve. I have a question regarding the issues I am currently experiencing on a production line that uses an Omron CS1H with a cimrex 69 HMI. The issues are the following but NOT CONSISTENT which really confuses me and on each power down of the PLC gives a different scenario:
1: When the machine is firstly turned and initialized it doesn't always return the a cylinder to its correct position. I have checked the position of the cylinder before initialization to make sure the sensors are correct but its pot luck if it goes into the right position and will not run if the cylinder is not in the home position.
2: Sometimes the data bit addresses representing parts present on the line show that there is a part in the line but the sensor I/O for that part shows there is not? Again this is not always consistent when I reboot but I can't start a cycle until this condition shows there is nothing on the line.
Is it possible that the memory of the PLC could get corrupt by a poor grounding issue? It is using a dirty earth!
How can I check if the memory is corrupt?
This machine was working poorly but after being down for a day for electrical fixes! i.e. e stop reset button seemed to deteriorate even further!
Apologies if these questions seem a little dull!
Cheers all!!
Cheers all!!
