newbie to PLC programming
Daniel45
Oct 2013
Michigan
I have been using PLC's very many years, I understand what they can do, but new to programming PLC's. I am working on programming an OMRON ZEN PLC for a very simple operation press start button run output 0 for 15 seconds then output 1 for 30 seconds and alternating until the stop button is pressed I have attached my attempt but I have something wrong, I would appreciate help in getting it right. I think once I see it correct I will have a better grasp of how to do this. Thanks
Here is a suggestion. There are other ways to do this. The "coil" for T0 and T1 should be switched on with contacts from Q2 on a separate rung.
I have been reading both the ZEN software support manual and the ZEN operation manual there is so much basic relay logic junk in the ZEN manual I jumped to the software manual and I haven't found what I am after there, I guess I will have to just wade through all the "noise" usually I can just pick this kind of thing up and figure it out with out having to read every word in the manual
Old Daniel is probably tearing out hair by now. Here is a big picture hint.
Remember that relays, timers, and counters have two parts: the operating "coil", and the contacts.
In Lancie1's example, I1 has to be NC not NO for the latch to work,...
Yes, study on this some more. I1 should be open to look at a closed STOP pushbutton. About 99% of physical STOP pushbuttons have a Normally Closed contact. Why?
Because the physical STOP pushbutton should correctly be NC, what type of PLC instruction do you need to use to LOOK at or EXAMINE that physical stop button and determine if it is ON (N.C. or not pushed)? HINT: It is always the OPPOSITE of the state of the physical STOP button contact. Once you get this clear in your mind, you will avoid one of the most common beginner mistakes in your PLC programs.
I am sure that in your work with electrical controls you have found that STOP control pushbuttons are always N.C. What you really should have done is change the state of your I1 switch contact (not the PLC program instruction "contact") in the ZEN simulator from N.O. to N.C. Then it would have worked as I programmed it for an actual STOP pushbutton.
hi ppl, appreciate if anyone can give a help here. I have a panasonic afpx c60-r which its output is connected to the switchgear module that...
1,601
Hi, after 30 years involved with automation I'm actually writing my first PLC program and am struggling a fair bit. My background is mechanical...
1,901
I picked up a Siemens S7 1200 from a buddy and I want to start fiddling around with it to learn about PLC's. I don't want to spend a lot of bucks...
2,479
Hi Guys I completed a PLC course a few weeks ago and I've decided to build myself a PLC training rig. I'm using an s7 200 as I managed to pick...
3,147
Hopefully I'll have a legitimate copy of RS500 to program micrologix and SL500 series PLCs. A guy in another group is going to mail me his old...
1,844
