http://www.avotraining.com/common/documents/avotraining/Electrical%20Hazards%20Analysis.pdf
useful article covering this topic
Originally posted by MikeW[/b}
The law was created because too many people were having accidents. It has reduced electrical accidents significantly since it was enacted.
Most of my outputs are fused at 2.5 to 5 amps.
2.5 A will kill you dead
Actually, 2.5A will kill you dead 50 times over, or more.
Yeah, but you won't really care about the last 49 times...
Don't need a arc flash study for 120 vac circuits unless they are fed by a 125 KVA or larger transformer. The only real hazard is the shock potential. Most of my outputs are fused at 2.5 to 5 amps. Again I contend that using rubber gloves while using insulated, slip proof leads adds very little to my protection.
The only hazard in the case I describe is shock. Shock hazard per NFPA requires insulated tools and rubber gloves.
The thing you should be working towards is what I've spent years doing, converting all your field I/O to 24 VDC. There is no problem with working on 24 VDC with your bare hands.
What would happen if there was an arc caused on the line side of the fuse.Arc flash is a function of fault current and with a 2 amp fuse fed from a control xfmer, there is no arc flash hazard. The only hazard in the case I describe is shock. Shock hazard per NFPA requires insulated tools and rubber gloves. If I have insulated tools / leads I'm protected from the shock hazard... rubber gloves seem redundant. Could I touch a live with my hands..of course, could I touch a live with my elbow..probably..so why not wear rubber sleeves....heck I might bend my knee wrong and hit a termial strip...rubber pants? I'm ranting and I know I'm loosing the fight..so I'll purchase my gloves...set up a PM schedule to have them tested every 6 months and go about my business as safetly as possible.
