Small panel disconect (NFPA79 / NFPA70E)
JOLTRON
Aug 2006
MI
692
I am designing a small panel. Inside of this panel there will be a 120VAC to 24VDC power supply and an Ethernet switch. This will distribute network connections to a group of cells.
My thoughts:
This is not an industrial machine so NFPA79 would not be required (therefor the disconnect would not be required to be interlocked with the door.
According to NFPA70 2014, the index shows section 409.30 for 'industrial control panels' but when I go to this section it covers 'Disconnecting means that supply motor loads'.
So can I use a side mount rotary disconnect that is not interlocked with the panel to save some mounting plate real estate? The panel would require a tool to open
Or am I missing a section of the standards?
Hi, Since a few here work with control cabinets and design I need a hint on where to find thin long lastning tape that I can tape on a panel front...
1,703
si'm looking for a small,inexpensive, touchpanel HMI that can connect to a printer to print simple text reports. The HMI will read data from a...
2,219
I have a few remote locations that are relay logic panels. I would like to monitor the panel with an AB micro 1100 and a small panel view. I would...
5,674
...and I agree. Context: TIA Portal/HMI = KTP1200 (12" screen) In the attached redacted image, the values in the white boxes are entered by the...
722
Hi all, I’m new to programming and want to write a simple routine. Push start button, turns on sensor. 2 second delay before anymore logic read...
336
