No-break redundancy
Farnesi
Jun 2009
Austria
46
Hi fellow automation friends lol
Do you guys know no-break redundancy solutions? I need a good one. Any suggestions on companys/technologies?
I work at a chemical industry which has a specific process that cannot stop no matter what and sometimes even the no-break fails.
Oh. How could it be named "no-break" at Brazil? LOL. Weird..
Just googled UPS and found out it is Uninterruptible Power Supply (UPS)
Well, anyway, any suggestion?
Seems that No-Break just means UPS.
Edit:
Seems it also means "I'm too slow to type a response"
I've seen it used to describe a UPS with generator backup. So that the output is feed by the UPS until the stand-by generator gets up to speed and takes over running the system.
I've also seen it used to describe a large fly wheel (or other stored energy) that can keep a line-powered generator running when utility power is lost and has enough momentum to keep generating power until a diesel back-up can be brought on-line.
No break means online UPS - some are not online but have a changeover mechanism from mains to battery.
Hi All, We are using S7300 CPU 317-2DP with Software Redundancy. The Backup link for Redundancy is via Ethernet. Suppose PLC-A is Master and...
3,241
Hello everyone, I am trying to change the IP address of the Omron PLC (NJ30-1200) and HMI (NB7W-TW01B) to fetch the network on our network...
308
I am having some trouble understanding what the break frequency is on a pf755. This is set in parameter 63. Rockwells description reads like the...
795
Hello everyone. I want to do a project. I want to monitor signals from HMI Panel. For example, I want to see this signal on the screen when a...
20
4,933
