NO/NC alarm
Just a bit from my own experience. Coil failures on relays do occur but I've had a lot more failures from the contacts - 10 A contacts switching logic signals is the big one that comes to mind. The contacts eventually carbon up and will not pass the signal when they are closed.
If you are using a relay to transmit a logic/low current signal (as I've inferred from your post), you might want to consider gold cross-point contacts on your relay. They are rather expensive and not available on all relays but, for those few times you are using a relay in these situations, they work well.
Hi- I am configuring an alarm and event server to display 1 current alarm at a time on a big display. Having a few issues The alarm doesn't...
70
Hi folks, in the alarm manager of Rslogix 5000, the tag-based alarm has been created. But when I tried to change the condition, it was found the...
158
From the Red Lion website, after some customer enquiries in the last week or so... Rev. March 25, 2024 [18:30] Just thought it might help a...
279
I'm a newbie who started a job as a repair tech recently. I've had plenty of luck with ABBs, Allen Bradleys, and a few others, but I can't seem to...
176
Hello, I made a change in alarm setup in factory view studio, where I changed a alarm message text. After that I made a run application and...
141
