NodeRed Modbus Inputs/Outputs
bradjeppers
Mar 2023
Denver, CO
Hello everyone, I'm hoping to find some answers on some Freewave programming through NodeRed. Hoping someone is proficient in this and is able to help. We've tried everything and nothing is seeming to work.
We are receiving our inputs but our outputs are not triggering. We have our programming in this order on the designer
Inject > Function 1 > Modbus Flex Getter > Function 2 > Modbus Flex Write > Modbus Response
Are we missing something in this to trigger the output?
Thanks,
Brad
I think you might receive more help if you was to "EXPORT" your program so that we could import it and look at how you have everything programmed.
As it is now there would be way to many parameters involved that could stop your "FLOW" from working as you think it should.
This is just my opinion.
Hello Old Man,
I have attached the .Json file with the flow! Our input coming in is not connecting to the output of the other radio (sending output). We are getting the communication between the 2 radios but the coil is not pulling in on the output radio.
Hi Everyone, i was hoping for a little help with this module. i have data that needs to be read from a different plc through the Modbus plus...
237
I have a PH meter that I am trying to bring its data into 1756-L81. I have downloaded the Rockwell MODBUS AOI kit, but I am not sure if I need to...
176
Dear All, i am trying to connect Danfoss inverter with s7 200 cpu 226.but microwin shows following error at DATA Ptr.i assigned different VB...
48
I'm trying to control a device via MODBUS RTU and the ModbusRtuMasterV2_PcCOM in Twincat 3. I've configured a device with the right com port and...
222
Hi all, Currently having trouble getting a speed reference to write over modbus to an Omron M1... I can successfully write a run command and...
258
