Nodes not found in RS-Linx
godfrey
Apr 2002
Charlotte, NC
412
I have 4 nodes on a DH+ network. Occasionally, when I view WHOs active, I see in addition to my 4 nodes, a whole screen of nodes which are covered with a red X. I think there is a way of limiting the number of nodes which can be browsed but I can't find mention of it in Help or manuals. Anybody know? I'm using Linx v2.2.
Drivers
godfrey,
Do you have any other drivers running in linx besides your DH+ driver? Maybe a driver for RSLogix 5, RSLogix 500, Devicenet. Sometimes when I use a laptop from another electrician who has different equipment then mine, I see his PLC's listed with red X's when I do a who's active to get online with my equipment. What type of node's are they, PLC's, Drives?
Zetor
Just do a right-mouse click & select remove
An in-active node will go away, an active node will pop back up again
After more digging, I found out how to limit the number of nodes to be browsed. I right clicked on the DH+ network, clicked on properties and there was the dialog box to do it. I also found that there were no terminating resistors on the ends of the network. You really have to keep after those co-op students. After adding them, the extra nodes stopped appearing.
I'm trying to connect a PV550 (2711-T5A2L) to a 1761-NET-AIC using a 1747-C11 cable (w/RJ45 removed) and the Phoenix connector. Can someone tell...
2,668
Hello, I have a forming machine that has a SLC 5/02 and Panelview 300 terminal. Unfortunately, the machine was seldom used and the battery quietly...
4,502
Hi, I am looking to migrate some of our Electronic Overloads off of a Troublesome Devicenet Segment. Is there any documentation confirming the...
114
I've been called to a site to assist with an ASi fault. The line has been down for a couple of weeks following a failure of the ASi power supply...
1,320
We have a devicenet consisting of 15 PF755 drives in a centerline MCC, and on a separate trunk cable coming off the scanner, a single PF525 in a...
346
