Non contact or spli core Voltage
asterof
May 2007
Califonia
554
I need to measure the voltage on three phase circuit
It is not posible to shut down the power in order to
connect onto the cable connection.
I once saw a non contact clamp on voltage transducer
but can not locate it on the web now.
Any one can offer any ideas.
but can not locate it on the web now. Any one can offer any ideas. Thanks
When I worked at Trojan we had a ten (??) foot insulated hot stick with a meter on it for checking 12,500 VAC switchgear.
You may be able to do something like this - depending on your voltage. The current era of flash protection may also make this more difficult. How often do you need to take these readings? Place permanent meter on switchgear ?? What kind of resulution do you need?
Dan Bentler
We have a customer asking us to measure the temperature of a moving chrome covered roll that is near room temperature. We aren't allowed to paint...
2,428
Good afternoon, I have an application where we induction harden different areas on our assembly part using coils that wrap around and heat up to...
3,734
Anyone out there have experience with non-contact length measurement? If so, please share your successes and lessons learned. I am looking for a...
2,293
We've had an intermittent issue with this for years. The application is sensing a level, or more accurately the absence of level in smallish ~5-10...
7,452
I need to replace the measuring wheel of a cutting system. Problem is that I do not have enough space in the machine and the cutting process is so...
2,135
