Non-contact length measurement
drforsythe
Aug 2016
Metro Detroit, Michigan
230
Anyone out there have experience with non-contact length measurement? If so, please share your successes and lessons learned. I am looking for a way to measure the length of material that is paid off from rolls onto an extruded substance. I cannot use an encoder with a measuring wheel and the variety of materials and their thickness variances will not allow calculation based on roll revolutions or roll diameter. Ideally, our Mfg Engrs want the data to go directly to a database, but it would be best to buffer the data through a PLC to know when the machine is running and allow direct association with the products we run. We use A-B Compact/ControlLogix so an E/IP interface would be the best form of comms for us. Any experience (good or bad) you have would be greatly appreciated. I have searched the web and found a few options, now I need to know what works and what does not before I talk to someone in sales.
Thanks for your time!
I've used the Beta Laser Mike device for length measurement on clear plastic film at speeds up to 1200m/min. Interfaced to a S7-300 plc over Ethernet using UDP
Two things I recall dealing with laser doppler velocimiters:
1) Very expensive, although the prices may have come down in the last 15 years since I last worked with them
2) You need to control the distance from the laser sensor to the product. the unit I dealt with had a decent tolerance, but there was a distinct limit
I worked with a unit made by Canon, and I had a colleague who used hardware from Laser Beta Mike. I had no complaints about the accuracy or reliability.
Proton InteliSENS is another option for a laser doppler sensor, I had a similar experience as OkiePC, expensive but works well.
As the other guys say, these are not cheap....
some of our other factories use this :
Limab UK
GA5103-0112
LaserSpeed Pro LS8500-403
And we are in the process of looking at getting one to measure the length of board as it goes along the outfeed conveyor from our press.
I am looking for a non contact lengh measurement system similar to the laser speed 4000. Is anyone using another manufacturer? What's a...
36
16,909
We have a customer asking us to measure the temperature of a moving chrome covered roll that is near room temperature. We aren't allowed to paint...
2,427
Good afternoon, I have an application where we induction harden different areas on our assembly part using coils that wrap around and heat up to...
3,724
We've had an intermittent issue with this for years. The application is sensing a level, or more accurately the absence of level in smallish ~5-10...
7,451
I need to replace the measuring wheel of a cutting system. Problem is that I do not have enough space in the machine and the cutting process is so...
2,133
