Non-siemens branded HMI with s7-1200?
somlioy
Jan 2011
Localhost
27
Hi
I currently got a system with 2 Siemens KTP600 mono running with a s7-1200 plc for a pumpsystem on a fish carrier. But the customer didnt like those HMI-panels because its not possible to turn it off completly without taking the power. Even with the screensave running the backlight is shining through and light is not popular at night.
So I'm wondering if someone knows a good HMI-panel that has the feature to blank the screen or something.
Also, how much fuzz is it to get non-branded siemens screens running with this plc? I mean, in TIA its just create a button and assign a tag from the plc for KTP600.
Schneider Magelis HMISTU655 maybe?
At least it has driver for s7-1200 ethernet (CPU 1211C,1212C and 1214C) and backlight can turned off after certain minutes of inactivity.
I have not done siemens project with it, but there is variable import function from .asc file
if we need to take back up of Siemens CPU(s7300 /s7400) with non siemens slave profibus nodes without their gsd files and when we restore it in...
83
What he have is a HMI2GO unit ( KTP900F) and we use a safety relay to trigger our e-stops. What the tech wants to do is guard against e-Stop on...
1,865
Hello Guys, I have s7-315-2 PN/DP with integrated DP. I have no CP module. PLC should be DP master. ON other side there is basler device DECS250...
3,487
Is it possible to use a non Siemens memory card with a Siemens PLC? And if so how? Would thought you should be able to configure any Memory Card...
2,491
Hy guys, I want to check if I can use a Siemens Sinamics S120 drives for the below Leroy Somer motors: Leroy Somer Dyneo motor LSRPM 90 SL, 4.8...
2,796
