Noob question: Backup, FX3U-48MT/ES
lensmaker
Dec 2012
Dallas
You'll quickly realize I have very little knowledge about PLCs. Please clarify a couple baby-noob questions.
I am working with a polishing machine used in the production of ophthalmic lenses, utilizing a FX3U-48MT/ES PLC. The equipment has various machine (customer) settings which can be modified through the HMI. There are many such machines that require the same customer settings. I would like to make a backup of a standard set, and import that backup to all other pieces of equipment. Also, in the case that the PLC software is updated, I would like to be able to reinstall the customer settings after the software update.
Are each of these possible? What is the procedure for backing up these customer settings? What is the procedure for importing these settings?
We use MDT's Autosave, but I don't think that it is FX aware. Which in that case I wouldn't bother with Autosave. Not much help, there...
I see that there is a program called Sellwood3u, which might do it. The company that made the software seems defunct, but an older version looks to be available.
I work in a field where our plc and hmi are constantly being powered fully off and on daily before being sent out. I am new to the world of plc...
967
Please laugh… but can I take 24volts from an IO module and wire it straight into its own input card to simulate an input….?
1,268
Hello. I'm wanting to use a boolean value associated with turning an output on to control the visibility of an image. The visibility option in...
2,161
Hello, I did a programming using MOVE block. However, whenever i press input. The MOVE block does not read the value assigned to transfer. Instead...
2,644
Hi, I have tried everything but still having no luck. This will be a easy solution I just know it. Ok I want to be able to set off an output...
1,796
