Not able to make object "VBA contolled" (sos)
sachincool786
Dec 2014
india
48
Dear Experts!!!
Actually i have two problems :
1. I want to change the object (FT View SE v8.0) property to "VBA controlled". But its not allowing me to do it, like as you can see on the pic.
2. I want to make an array of objects in FT View like as shown in the pic (Image of VB form): the object name is azul and the index is 0 so the object shown in the pic is azul(0)
VB Form code is :
Private Sub Form_Load()
Dim i As Integer
For i = 1 To 224
Load gris(i)
azul(i).Visible = True
Next i
azul(0).Visible = True
For i = 0 To 224
azul(i).Top = gris(0).Top
azul(i).Width = gris(0).Width
Next i
For i = 0 To 224
azul(i).Left = azul(0).Left + i * azul(0).Width
Next i
End Sub
As you can clearly see in VB code I have created one object only, but rest of the objects are being created by Code only
I want to do the same thing in FT View SE v8.0
Please please help!!!!!
Hi all. I'm running a VBA code on my FTView which is actually working, but everytime I open the display that calls the VBA code, it throws the...
28
1,824
Many of my current projects include I/O status screens listing all discrete inputs and outputs by module, with a description and on/off indicator...
6,963
Have a very simple global object that passes three parameters to open the (ra-bas) common-analogedit popup. The min and max and the popup always...
1,615
I have a requirement to implement in factory talk view studio se It is to block the user from interacting with the display, sort of disabling...
4,219
Dear Expert. I have problem to rotating the objects. (object from Graphics) Tool bar, Format menu, Rotate is disable. Is there any option to...
2,122
