Novice!!!
gerryrowe
Sep 2009
ireland
a little help would be much appreciated so ive been challenged with a project with a siemens PLC ive got 4 air controlled Rams,only 1 is Spring controlled,We'll call them A B C D,my programme is to function A+,C+,C-,A-,B+,B-,D+(if my part is of the wrong Size)ive hit trouble can any 1 hepl me with a ladder diagram sollution Pleas!!!:oops:oh also ive got a start,stop and manual/hand selection not PLC controlled
How about the D-? Is it the spring returned? How long does it stay on before turning off?
The first thing you MUST do is define your process. How does it start? How does it know when to transition to the next event? How does the process end? What should it be doing while it's just setting there "idle"? etc., etc., etc...
Answer these types of questions, then try to organize the information into a flow chart, or a process narrative, or pseudo-code, or whatever it takes to write out exactly how your process is to work.
Only after you have done this can you start programming. Or expect any help.
So far, with what you've given us, we CANNOT help you. We don't know what your homework assignment... er... "job task" is. We cannot read your mind.
my projest is a part selector/rejector programme.when my part,X is entered ram A pushes it to be measured by ram C.the part is sqaure in shape but can be measured by ram c either almost fully passing through x,or if the part size is incorrect ramC is not allowed to almost fully pass through.regardless ram B,after ram C and A have reset,then extends and resets,if the part is of correct shape ram D,does not function,however if the part is the incorreect size,ram D will shoot the piece to a rejection bin,is that any help?Thanks for the response BTW
Hi, first time poster just wondering if anyone has any tips for a novice of the PLC world, I've worked with them a fair bit within schooling and...
3,252
We're a used machinery merchant and have a Siemens PLC that has lost its program due to a dead battery. We have the software to download but, at...
22
6,636
Hi I’ve got a door and window switch from RS (190-1011) with a 4 core cabl - red, white, green, and yellow . The red and white are the switch and...
1,358
I'm self taught so far, so hang with me as I try to explain my issue. I've got an archived program file for a PVP6 that I'm opening on FT ME ver...
2,598
If 95% of our PLCs are AB (micro 1500, slc5/03,04 make up the bulk) what would be the language to learn to use scripting? Also to move towards...
2,166
