Nuance Plc fault
David_Emmerich
Sep 2002
Smiths Grove, KY
671
Hello again!!!
I have an interesting problem in our Boilerhouse control system...almost every morning when the sawmill starts to bring all of their large loads online, the 6 feedscrews on our fuel system drop out. We have run a recorder on the incoming 480 lines but only see a 1 or 2 volt drop. I put a recorder on the 120volt feed to the PC rack (AB logix5571) and saw it dip to 115 vac when the 6 drives shut down this morning. Any ideas?
Are the feedscrews motors VFD controlled? What is the fault mode when "the 6 feedscrews on our fuel system drop out"?
Yep, sounds like noise to me too. i experienced something similar many years ago on a machine with loads of automatic positioning. Every time a big extruder nearby started and stopped, I would lose half of my encoder cards. The situation was resolved by moving the extruder to a different transformer.
Nick
So Last week there was a discussion on new laptop options. Looking at new ones got me trying to strategize as best I can when I also have to make...
2,304
HI everyone, i am new to Siemens plc programming and i am in need of some help. yesterday we had an S7-1200 CPU 1214C fail to turn on an output to...
Hello, I have a Mitsubishi FX3G 14M PLC and a E615 HMI from Mitsubishi/Beijer. I'm using GXWorks 2 to do the programming and I have no problem...
52
Hi, I'm trying to import a Rockwell/AB EDS to Beckhoff but I'm not sure how to import/install the EDS. It is a PowerFlex 525 EDS. Is there a way...
74
I want to communicate my Q series PLC with Factory IO using GX works 2 software, I want to use modbus as server and the ips are as follows plc...
49
