Nubee With Ethernet/IP Socket Create MSG Error
FreeAtLast
Mar 2019
Nashville
38
Good Morning Everyone,
I'm new to explicit TCP/IP communication and I am getting an error code when I try to create a socket.
Studio 5000 32.012
client - 5069 PLC
server - Flexibowl feeder
I can send commands to my feeder over UDP and cause it to move, shake, etc. But as soon as I try to send an explicit command (for example to adjust a speed setting) I get an error code from the MESSAGE instruction.
When the AOI tries to create a socket I get the error code "16#0016"
with error text "Object does not exist". (See attachment)
Does anyone know what that means?
The logic that the MESSAGE instruction is inside of is a mature AOI from the manufacturer (flexibowl) so I don't have any reason to believe there is a problem in the logic.
Thanks for the help
It looks like I had the wrong path. I was pointing to the server. When I changed the path to "THIS", the error went away. I haven't been able to do a socket read, but I think that is a separate problem for another time.
Thanks.
Nubee question on latching and unlatching relays I have a customer with a Data center configured like below: What I am trying to do is: If...
2,796
159
Can we use a Simotion D455 ethernet port x127 as a gate, to access S7-1500 plc Tia Portal program ? In the Simatic manager, we used Netpro to do...
89
So I have a sort of unique situation where I'm wanting to run a PF755 from the IO and over ethernet. Of course, this comes with it's own set of...
275
Hi all, My ethernet port on my laptop recently broke and I was hoping to just use a usb-c dongle in the mean time to go live on my PLC until I...
454
