Numa logic Westinghouse PLC
t0r3r0s
Mar 2015
Gracanica
I have problem whit communication on this device .
When I check pc status in softwere i get error type "communication error".
My cable for RS232 communication is DB25toDB9toUSB is that problem .
And have any one examples program for this device .
Thank you
http://www.esteem.com/files/files/E91013.pdf
The above link will show the communication pin out for the controller. Has you cable worked before? If so, I would remove the DB9 to USB device and use a computer with a serial DB9 port to test.
I have personally only had luck with the Sabrent USB Serial DB9 converters.
Regards,
Garry
http://www.accautomation.ca
I just got this pic, such that the first time I try to communicate with him, however, does not go on this way described. do you have maybe some examples that you did
Regards,
Semir
Hi I am brand new to this site but have programmed PLC's since the early 80's. I just acquired an older dial machine that has a Westinghouse PLC...
2,124
Can anyone tell me what Westinghouse PLC family uses the NL-302 input card? Mike
1,676
I have only a print-out from a Numa Logic PLC to convert to AB RS Logix code. Can anyone help me understanding some of the more complex...
6,835
I'm converting an old Westinghouse Numa-Logic PC1100 ladder listing to a TSX37. My problem is that I don't have any user manual for the PC1100, so...
4,911
Does anyone have information about Westinghouse Numa Logic syntax. I have a hand written document which contains DS40, T12(timers?) Outputs like...
3,797
