Numatics G2-2 Devicenet EDS File Required
Apr 2020
Richardsbay
Hi all. Please can anyone assist me with a Devicenet EDS File or link for a Numatics G2-2 solenoid valve bank. Need to do configuration on a 1756-DNB Devicenet Scanner used with a RSLogix5000 PLC Control System. It is such old equipment that I cannot find an EDS File to download anywhere. I believe Emerson has bought out ASCO Numatics but no luck on their website. Much Appreciated.
DeviceNet EDS Files for G2-2 Numatics Valve Bank Downloaded
Hi gtsuport.
Thank you for the link that led me to the DeviceNet EDS Files for G2-2 Numatics Valve Bank. This is a real pot of Gold.
I've managed to download the correct EDS File & configuration for the G2-2 Numatics Valve Bank to the 1756-DNB Scanner, no more #E77 errors
as Input & Output Size Bytes are matched now.
Much Appreciated.
Jaco van Niekerk.
:site:
Anyone got a manual for one of these? I cant find anything online.
1,294
Hello, I've dealt with Communication faults on these ethernet nodes a few times but I never feel like I have the right solution. i usually replace...
666
Does anyone have any alternatives to the Numatics 502 manifolds that have Ethernet/IP adapter functionality alongside the valves? If they have m12...
3,431
Good morning, I have a dispenser that spits out ring gears for a robot to grab. This process has been running as expected for years. Currently...
2,072
Hello there, i have a g3 series solenoid bank whit a fault code that says "valve power off", i went online with the g3 using the web browser but...
2,055
